Latest: sparrowdclxvi
Overall: 17139
Online Now [232]:
Visitors: 231
Today: 16384
Total: 112404378
Forums › The Car › 206 Problems › TORQUE STEER
TORQUE STEER
Go to page Previous  1, 2, 3
Sprint955
PostPosted: Sat Jul 02, 2011 10:09 am Up
Strange. Sons' car 1.4 206 LX on an 03 plate pulls to the left under acceleration and steers right when you take your foot off! Most noticeable between 60 and 70mph. Left near side tyre's quite worn on outside edge. Tracking out possibly but the car was fine 2 months ago so what would upset the tracking so suddenly?
I prefer bikes
PostPosted: Sat Jul 02, 2011 10:20 am Up
1 good smack against a kerb or down a pothole would be enough to knock the tracking out.
kevd
PostPosted: Sun Jul 03, 2011 2:54 am Up
Hi
i would suggest you get the ball joints/bushes tyre pressures and tracking checked first. if those are all ok then you could end up going down the same route as me.
2 new wishbones 3 if you count the one just over 3 months old and still looks like new
2 new drop links
2 new track rod ends
2 new pich bolts for the hubs
Good luck
Kev
Kev
lennyboy
PostPosted: Fri Feb 21, 2014 10:30 am Up
I had this problem and it was the bushes nearest to the bulkhead on the lower suspension arm
D4NTP
PostPosted: Sat Feb 22, 2014 3:12 am Up
I had the problem on my corolla the other year after the g/box was changed (don't worry it wasn't the box causing it) because the retards at the garage failed to tighten up the suspension arm correctly. I'd be very surprised if it was anything other than a worn bush or something left loose, possibly after the tracking was done?
splodgeink
PostPosted: Sat Sep 10, 2016 6:21 pm Up
I would like to add after trawling many posts on this subject that replacing the wishbone to hub nut and bolt with genuine parts appears to have solved my issues.
Page 3 of 3
