Posted: Mon Jun 27, 2011 10:47 am |
How much would it cost to get my air-con re-gassed???
It used to work but then the car was sat around for nearly a year without the A/C being used and when I push the button you can see a slight drop in the revs so i'm pretty sure its all working but just needs gas
Thanks,
Ben.M
| "Being second is to be the first of the ones who lose. " Ayrton Senna | |
Posted: Mon Jun 27, 2011 10:49 am |
would say between £60-100 depending on where you take it
thats assuming its just drained out over time and just needs a straight forward re-gas
if it is a leak thats causedit then the cost starts to esculate quite rapidly :/
Posted: Mon Jun 27, 2011 10:51 am |
I thought regassing was about £30
Posted: Mon Jun 27, 2011 10:53 am |
Lee wrote: |
I thought regassing was about £30  |
Me too, I got told it's about £28 to re/gas my aircon
Posted: Mon Jun 27, 2011 10:54 am |
Lee wrote: |
depends how its done
we charge £70 at work but that is a full drain, leak checked then if passes is re-gassed with the correct amounts of gas and oil (with combined uv leak detection dye to help easily pinpoint future leaks) and a pollen filter change
Posted: Mon Jun 27, 2011 10:58 am |
Ok thanks guys, just hoping Lee and hobnob are right Drove into college today and was so tempted to stick my head out of the window like a dog, it was that hot in the car even tho the fan was on cold and setting 4, need to get it sorted asap,
thanks again,
Ben.M
Posted: Mon Jun 27, 2011 11:02 am |
Most places I've seen for a good aircon recharge charge around the £70 mark.. Your backstreet "Low Pressure" fillers will do it for about £30-45ish, A true aircon regas removes the old gas along with moisture, checks for leaks and then refills using both the high and low pressure pipes.
| The Cars:
Peugeot 206 1.6 HDi GTi '06 Plate - O/H's Car | |
Posted: Mon Jun 27, 2011 11:11 am |
Ste206 wrote: |
A qualified aircon regas removes the old gas along with moisture, checks for leaks,evacuates the system and then refills using both the high and low pressure pipes. |
Gas doesnt just dissapear as said by other members its because of a leak.
Posted: Mon Jun 27, 2011 11:19 am |
true / qualified - Meh lol
They do actually advise you get them regased every 2 years anyway, aircon loses it's cooling effectiveness over time.
| The Cars:
Posted: Mon Jun 27, 2011 11:34 am |
Ste206 wrote: |
They do actually advise you get them regased every 2 years anyway, aircon loses it's cooling effectiveness over time. |
Yeah i can understand that with such a small amout of refrigerant in, just be careful there are MANY aircon cowboys out there. best to check they are F-Gas/Refcom qualified (Y)
Posted: Mon Jun 27, 2011 11:35 am |
As long as its filled up and works, who gives a s**t
Posted: Mon Jun 27, 2011 11:39 am |
Lee wrote: |
As long as its filled up and works, who gives a s**t  |
Me, if they overcharged/undercharged the system and damaged any of the components
Posted: Mon Jun 27, 2011 11:40 am |
Then they'd have to pay for it...
Posted: Mon Jun 27, 2011 11:41 am |
brad-morris wrote: |
Lee wrote: |
Me, if they overcharged/undercharged the system and damaged any of the components |
I have heard of a certain fast fit tyre place that does aircon damaging the system of a Ford Galaxy by putting to much gas in
Posted: Mon Jun 27, 2011 11:57 am |
Lee wrote: |
Then they'd have to pay for it... |
Yes, so why not go to a qualified engineer rather than the " fill it up aslong as it works " approach
