Latest: DanDan17
Overall: 17128
Online Now [434]:
Visitors: 433
Today: 40880
Total: 100641256
Forums › The Car › 206 Problems › heater blower
heater blower
gaffy
PostPosted: Sun Jun 26, 2011 10:10 am Up
hi everybody, recently my heater blower stopped working, i done a search on the problem, which made me belive that the fan motor had broken. I purchased a new blower unit an fitted it today but it still dosent work!!!! i have checked all fuses an all is good, so now im stumped can anybody give me any advice on my problem? cheers gareth.
chin up lad
PostPosted: Sun Jun 26, 2011 10:12 am Up
Resistor
gaffy
PostPosted: Sun Jun 26, 2011 10:16 am Up
hi lee, thanks for your reply but where do i find the resister?
chin up lad
PostPosted: Sun Jun 26, 2011 10:19 am Up
Take the glovebox out [couple of torx screws]
Set the heating to recirculation [the slidy thing, to the right hand side], then you should be able to access it
Turn the resistor and pull it into the duct. Disconnect the wiring, and remove the resistor.
Then refitting is just the reverse, basically
gaffy
PostPosted: Sun Jun 26, 2011 10:34 am Up
hi lee, forgot to mention that i have the digital heater controls is this going to make a differance? as i cannot see the resister. thanks
chin up lad
PostPosted: Sun Jun 26, 2011 11:18 am Up
There is no resistor on climate control models. The fans are specific to climate control models too. Buy a new one, not a used one. They fail all the time and there's a good chance a second hand fan won't last long.
AEP Direct do OE BEHR fans and tend to be cheapest.
gaffy
PostPosted: Sun Jun 26, 2011 11:53 am Up
hi edward, i did purchace a new climate control fan, but as ive said i plugged it in an no joy, so now im stuck to what i can do to solve my problem. Anybody any ideas? cheers gareth
chin up lad
Norvvv
PostPosted: Sun Jun 26, 2011 5:04 pm Up
Change the fuses, even though they look good they could be shot. Smile
2001 1.4lx
PrePlexed 5 door.
Slickrikk
PostPosted: Mon Jun 27, 2011 1:46 am Up
Scotland Area Rep - Slickrikk
What He Said
Aegean Blue 206 Gti 180
