Online Now [763]:
Visitors: 763
Today: 109453
Total: 149952243
Forums › The Car › 206 Problems › "Creaking" when accelerating
deanparkr
PostPosted: Sat Jul 02, 2011 5:29 pm Up
Hi all!
Quick question.. I have recently broken down twice in the last month once due to a broken front suspension spring and then again when the front exhaust fell off.
With those items fixed, now whenever I accelerate from standstill (like at traffic lights), if it is a fast acceleration I hear a "creaking" noise from the front suspension about 50% of the time.
I cant re-produce it when someone else is in the car listening typically as it seems to be intermittent.
Wondered if 206 experts might have any idea as to the cause?
2002 1.4LX
PostPosted: Sat Jul 02, 2011 7:38 pm Up
The suspension hasnt bedded in yet?
PostPosted: Sun Jul 03, 2011 3:08 am Up
This is normal in a 206. The 'creaking' is because under acceleration the body work is actually stretching due to the immense power from the engine.
deanparkr
PostPosted: Sun Jul 03, 2011 4:36 am Up
Ah, didnt realise it needed bedding in. I'll see if it goes away after a while then Smile
2002 1.4LX
Mike_XS
PostPosted: Sun Jul 03, 2011 4:39 am Up
Mine is still creaking after the new suspension has been on for nearly a month. I've been told it's most likely the top mounts. Have you replaced yours?
deanparkr
PostPosted: Sun Jul 03, 2011 4:44 am Up
Nope - how much are top mounts fitted roughly?
2002 1.4LX
Mike_XS
PostPosted: Sun Jul 03, 2011 4:49 am Up
Bearings are £25ish and Top mounts are around £45. This is what a mechanic I know told me. So prices could be different where you are.
Edit - Not sure how much fitted. Shouldn't take longer than an hour though.
deanparkr
PostPosted: Sun Jul 03, 2011 4:57 am Up
Cool, thanks.
I'll give it another week or so and see what happens and then get them to have another look if needs be.
Smile
2002 1.4LX
