Latest: DanDan17
Overall: 17128
Online Now [229]:
Visitors: 228
Today: 25611
Total: 100626015
Forums › The Car › 206 Problems › Heated rear windscreen
Twidly
PostPosted: Sun Jul 03, 2011 11:43 am Up
This no longer works. The light doesn't even come on when I press the button. Is it a fuse (I don't touch these anymore)?
Coincidentally, or not, this happened after I had a new ECU and BSI fitted by pug in February (after I wiped it after fiddling with a fuse)... Could they have f***ed it up when they did that. I.e. not programmed the function into the car?
Cheers...
P.s. How long before MrBSI or Lee answers this? Laughing
PostPosted: Sun Jul 03, 2011 11:58 am Up
Either the timed relay is dead, or its one of the fuses for the BSI. More inclined to say the time relay.
Could always check to see if there is +12volts going to the switch, then you'll know for certain
