Online Now [109]:
Visitors: 108
Today: 104868
Total: 140098211
Forums › The Car › Request a how-to › Removing 180 Seat Airbag Connector
Forum IndexRequest a how-to
rob_1990
PostPosted: Wed Jul 06, 2011 5:46 am Reply with quote Up
First of all I did search first but couldnt find anything. I need to remove my drivers seat as its wobbling and rocking, I have undone the 4 torx bolts holding the runners down and left the battery disconnected for about 30 mins before hand. But i cant get the airbag connector to split. Please can someone point me in the right direction?
Danny.
PostPosted: Wed Jul 06, 2011 6:14 am Reply with quote Up
Does that orange/red tab not pull up?
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
rob_1990
PostPosted: Wed Jul 06, 2011 6:15 am Reply with quote Up
It does pull up yeah, but that doesn't seem to do much...
EuroPeugeot
PostPosted: Wed Jul 06, 2011 7:42 am Reply with quote Up
I had the same problem the other day, I gave up in the end Sad
Anyone know..?
PostPosted: Wed Jul 06, 2011 7:45 am Reply with quote Up
Lift the tab and pull?
When I had my wiring repaired by Peugeot they cut the connectors out and hard wired it Confused
EuroPeugeot
PostPosted: Wed Jul 06, 2011 7:47 am Reply with quote Up
That's what I'm going to do I think.
Disconnect the battery for half hour, cut the wires and hard wire them back in.
That should be fine, right?
PostPosted: Wed Jul 06, 2011 7:51 am Reply with quote Up
That's what Peugeot did so it must be Laughing
(I didn't have any issues with it)
copey
PostPosted: Wed Jul 06, 2011 8:30 am Reply with quote Up
suppose its a good idea, just a ball ache if you plan to remove the seats again
02 2.0 hdi d turbo
PostPosted: Wed Jul 06, 2011 9:24 am Reply with quote Up
Just use insulated crimps.
The reason why they chop them off and solder and heat shrink them is to stop the airbag fault. Loads of companies do this now.
rob_1990
PostPosted: Wed Jul 06, 2011 9:43 am Reply with quote Up
Ohh seems extreme. The reason im trying to take the seat out is because its rocking back when i accelerate. When moved it earlier a bolt which had sheared off fell out of somewhere, anyone else had this?
Defjester
PostPosted: Wed Jul 06, 2011 1:36 pm Reply with quote Up
Ive just fitted the Gti 180 seats into my 138 Gti and couldn't get that connection apart either, the red tab snapped off when i lifted it Confused
Has it come out of the part of the runner that's attached to the seat?
Pilots a China Blue Frog Rocket
HFStuart
PostPosted: Wed Jul 06, 2011 3:56 pm Reply with quote Up
Turn the connector over from how it's shown in your photo. There's a little green tab that you'll be able to push down and it looks like that frees it - but it doesn't
You need to get a slim screwdriver and slide it in just beneath thab tab - give it a wiggle and the connector can be pulled apart. Took me a while to work it out and I've done a few over the years.
Edit: Camera found - Like this mating half missing but you get the idea.
Stuart
rob_1990
PostPosted: Wed Jul 06, 2011 4:31 pm Reply with quote Up
thanks mate, that worked a treat!
Stuart
sambelsher
PostPosted: Tue Feb 14, 2012 7:00 pm Reply with quote Up
hi i have a simuler problem i remover the standered seats and put some recoro seats in my 206 GTI and i am getting airbag fault is there any way i can join the cables together to make the car think the airbags are still there to get rid of the airbag fault if so what cables do i join together there is 3 cables going to to the plug
burn rubber not your soul
sambelsher
  Quick Reply
Username:
Message:
Quote the last message
