Posted: Sat Jul 09, 2011 2:24 pm |
Hi all, New to this but wonder if anyone can help?
My Car died a few days ago, after engine management light came on. I started up again fine and worked as normal too. Light went off after a day but same thing happens today, it seems to only happen after five mins of starting? Any ideas, I also have a problem with header tank not holding coolant properly wondered if that might be associated?
It's a 206 1.6 2001 Y.
Posted: Sat Jul 09, 2011 2:30 pm |
Get the codes read mate.
Posted: Sat Jul 09, 2011 2:34 pm |
Cheers pal is that something any garage can do or can you get a bit of kit to do it your self?
Posted: Sat Jul 09, 2011 2:36 pm |
Just take it to an auto electrician and chuck them a few quid for telling you what it says.
Posted: Sat Jul 09, 2011 7:28 pm |
Headgasket probably
| 2001 1.4lx
PrePlexed 5 door. | |
Posted: Sun Jul 10, 2011 12:27 am |
Norvvv wrote: |
Headgasket probably |
under what assumption lol??
the header tank loosing water could simply be a bad fitting onto its hose. the car "dieing" could be anything, fuel, electrical, etc.
everyone always jumps to the HG
Any work you undertake as a result of my posts is done so at your own risk | |
Posted: Sun Jul 10, 2011 3:53 am |
Where abouts are you from?
Posted: Sun Jul 10, 2011 4:24 am |
m.killeavy wrote: |
Cheers pal is that something any garage can do or can you get a bit of kit to do it your self? |
Main dealers or local garages with the right reader, or there's some people on here that do it like Lee ^^
