Latest: sparrowdclxvi
Overall: 17139
Online Now [697]:
Visitors: 696
Today: 33018
Total: 112545622
Forums › The Car › 206 Problems › ABS Fault
ABS Fault
smartyh
PostPosted: Sat Jul 23, 2011 7:22 am Up
Hi,
Got an ABS fault warning on my 2001 206 GTI. Found the ring on the drive shaft has broken (reluctor ring is it?) Anyone got a how to to replace it?
Have looked on the site but can't find what I need.
Any help appreciated.
SM
cartoonhead
PostPosted: Sat Jul 23, 2011 7:25 am Up
a new CV or i took my shaft out and put a jubilee clip around it , tightened it up to close it to the shaft and put 4 spots of weld on it and its been ok since.
smartyh
PostPosted: Sat Jul 23, 2011 7:52 am Up
Thanks for the reply, too far gone for that, it's snapped in half and sitting in my kitchen at the moment. Just hope the wife dont find it. She won't be impressed with it being in there.
SM
copey
PostPosted: Sat Jul 23, 2011 8:03 am Up
give her something to clean up later Laughing
02 2.0 hdi d turbo
cartoonhead
New CV joint it is then Sad
Andy180
PostPosted: Sat Jul 23, 2011 9:45 am Up
you can buy new abs rings off the internet they arnt paticuarly hard to replace and its cheaper than buying a new cv joint or driveshaft.
GTI 180
smartyh
PostPosted: Wed Jul 27, 2011 1:03 am Up
Where's a good on-line place to get a new CV joint from?
Many thanks,
SM
PostPosted: Wed Jul 27, 2011 6:05 am Up
I just got a new exchange shaft from the Peugeot dealer. Less hassle that way. EurCarParts sell the shaft but they weren't as thick as the original part.
AX-Rated
PostPosted: Wed Jul 27, 2011 3:51 pm Up
Can you tell me more Edward, on the procedure, as I wouldn't have thought that Peugeot offer this.
I found a crack around 3mm wide in the drivers side ring and been having ABS issues.
Even the ABS ight has been coming on recently.
Black 03 GTi
