Latest: DanDan17
Overall: 17128
Online Now [51]:
Visitors: 50
Today: 11177
Total: 100531122
Forums › The Car › 206 Problems › Drove fine and now doesnt start
p_anit
PostPosted: Mon Jul 11, 2011 12:38 pm Up
I had my car into the garage as something to do with the clutch went. Picked it up earlier and drove it home fine without any trouble. (5-6miles)
Just got into the car to take it for a spin and it now it doesnt even start or turn over. When i take the key out of the ignition the locks seem to be clicking loads but not as loud as if i was locking the car.
I can see the clock display come on very slightly and also the battery light in the dash but is very dim when i turn the key to start.
Ive tried to roll the car down the road and jump start it but as its not even turning over ive had no luck with that.
Has anyone had this before or have any idea what it could be.
Called the guy from the garage and he said he would be out in the morning but until then i have no idea.
99 Green 1.6 GLX!!! No Mods but i keep it clean!!!
PostPosted: Mon Jul 11, 2011 12:41 pm Up
Battery connected properly?
p_anit
PostPosted: Mon Jul 11, 2011 12:44 pm Up
I checked that and it seems to be connected ok. I cant understand as the car drove fine probably half hour before.
Rob2859
PostPosted: Mon Jul 11, 2011 12:53 pm Up
Make sure the earth on the battery is in good condition they are a bit poor. If you have jump leads connect one to the earth on the battery and the other side to something like the manifold and try it. If you do not have jump leads use some thick wire if you have any.
DREWDEN
PostPosted: Mon Jul 11, 2011 1:15 pm Up
Is your car diesel or petrol. sounds to me like a starter motor problem if its diesel.
206 2ltr Hdi glx 53 plate
p_anit
PostPosted: Mon Jul 11, 2011 1:20 pm Up
Its a petrol, just about to see if the earth is funny
gaffy
PostPosted: Mon Jul 11, 2011 1:56 pm Up
deffo check the earth is connected properly mate, had the same thing happen to me a couple of years ago.
chin up lad
tamz
PostPosted: Mon Jul 11, 2011 5:33 pm Up
av got the same problem , my feul pump isnt gettin an electical feed for some reason dunno why :/
Ash
PostPosted: Tue Jul 12, 2011 2:33 am Up
Check the fuses just incase.
Kersh
PostPosted: Tue Jul 12, 2011 2:42 am Up
maybe your crank sensor in the top of the gearbox got damaged as they fixed the clutch, happened to me. pop it out and check to see if its ok Smile
Member number: 36
p_anit
PostPosted: Tue Jul 12, 2011 8:30 am Up
Got the car going again with another jump start but have now locked the keys in the car. Does anyone know if the car deadlocks when the car trips from messing with the battery?
Have tried the old coat hanger but just not working....and don't have a spare key!
