Posted: Tue Jun 28, 2011 9:11 am |
Hi there
Anyone experienced this sound from engine room.
Seems from the timing belt area.
I did my timing belt and cam belt changed.
Is it the sound from some bearings ?
Thank you
www.youtube.com/user/s...fU9RxKaPpU
p.s. it is better to listen via EAR PHONE...
| Hello! my ride if 206 GTI S16 from HK | |
Posted: Tue Jun 28, 2011 9:41 am |
when you changed yr cambelt did you change the water pump as well it could be a tensioner
| 2003 Pug 206 2.0 GTI 180
IT TAKES TALENT TO BE THIS NOOB!!!! | |
Posted: Wed Jun 29, 2011 8:18 am |
I changed my cambelt and timingbelt on last year .
As I remembered , the garage said they changed a set of cambelt.
for the timing belt , just changed the "tension roller-belt"
No water bump changed, and is the tensioner linked to the timing belt?
if yes, I had not get it changed.
Thank you so much.
Posted: Wed Jun 29, 2011 8:26 am |
p.s. this noise come out when I was driving a while ? (warmed condition )
Is it possible from alternator bearing ?
Posted: Wed Jul 13, 2011 10:14 am |
Problems found !
Shd be from Water pump! and after refilled the "water" .. there is no sound in low temp and only a little bit sound at high temp!
