Posted: Wed Jul 13, 2011 2:06 pm |
Hi
I've noticed that the gap between my bonnet and drivers wing is slightly bigger than the gap on the other side
Its not a big issue but it annoys me. Is there anyway I can tweek the alignment easily to match?
The wings are aligned fine in themelves
Cheers
Posted: Wed Jul 13, 2011 2:12 pm |
Adjust the hinges themselves. Just loosen the bolts and twist the bonnet as you need to and just tighten back up.
Posted: Wed Jul 13, 2011 2:13 pm |
Yes loosen the bolts where the bonnet attach to the shell then move to the required position and tighten again.
They are 10mm I think from memory
| 206 180 rally car in progress. I may not be perfect but there are parts of me that are f£%$ing brilliant | |
Posted: Wed Jul 13, 2011 2:17 pm |
Thanks guys, I spotted the hinges had small bolts but I didn't know it was just a job of loosening them and repositioning it.. I was expecting to be told I'd have to take it off and put it back on haha
Posted: Wed Jul 13, 2011 3:02 pm |
as said but is quite fiddly job will take you a long time to get it perfect normally ends up worse first few times lol
Posted: Wed Jul 13, 2011 3:24 pm |
Its not diagonal or anything, just needs bringing to the left a mm or 2, so I will loosen the bolts, shift it accordingly and retighten
Is there a specific torque for the bolts to be tightened again?
Posted: Wed Jul 13, 2011 4:12 pm |
Probably but just do it till they feel tight
