Latest: Beduff1977
Overall: 17134
Online Now [367]:
Visitors: 366
Today: 809
Total: 106990860
Forums › The Car › 206 Talk › How do you take the steering wheel and Com2000 off?
bigup
PostPosted: Thu Jul 28, 2011 6:38 am Up
ive read how to do the BSI switch off
but how do i take off the steering wheel and the com2000 from a 2003 1.4HDI?
any guides? ive done a search too!
thanks
2003 206 1.4 HDi Style 3 Door
DeadEyePaul
PostPosted: Thu Jul 28, 2011 6:46 am Up
thanks
Searched www.206info.co.uk/Foru...wheel.html
Lewis
PostPosted: Thu Jul 28, 2011 6:50 am Up
2003 will be multiplexed though Paul, anyone know how different the steering wheel removal is from preplex to multiplex?
Tivoli LX 1.1
Black GTI 180
White VXR Burg
DeadEyePaul
PostPosted: Thu Jul 28, 2011 6:52 am Up
I assume you just have to follow the correct BSI disconnect battery procedure
PostPosted: Thu Jul 28, 2011 6:58 am Up
Look at the rear of the steering wheel, 2 holes, one on each side. The airbag is clipped in. Push the wire clips in with a screwdriver and carefully pull off airbag. (Disconnect the battery first and follow the BSI reset procedure)
Then there is IIRC a 22mm nut to undo and the steering wheel pulls off.
meady
PostPosted: Thu Jul 28, 2011 7:51 am Up
Trade Rating: +45
Its a torx (star shape) bit but not sure what size
TEAM - I HATE FACEBOOK Smile
Guy
PostPosted: Thu Jul 28, 2011 8:03 am Up
I can do for people who need it removed or help.
I have done it numberous time with new com2000 unit.
I noticed your in manchester. I am around manchester this weekend for awesome gti show :D, its VAG show Smile
Plus My girlfriend lives in sale.
Gone into VAG route with Audi A3.
Stuff still for sale!
PugJH
PostPosted: Thu Jul 28, 2011 8:07 am Up
2003 = mulitplexed.
Wheels straight
BSI shutdown. open window, remove battery cables, wait, push a screwdriver into hole underneath, airbag pops off, unclip all plugs, undo airbag,, unscrew bolt in middle of the steering wheel halfway, wack one side of the wheel to pop it off then pull towards you, then fully undo the bolt and remove, then pull the wheel off without smacking yourself, the com2000 unit is attached with 2 - 4 plugs, remove these then lift the flips that hold it to the steering wheel rack, slide off, then swap and reverse.
WIP: Black 1.6 16v XSi
Beauté Noire
bigup
PostPosted: Sun Jul 31, 2011 12:14 pm Up
ive only just seen your message mate! sorry, it would of been ideal too, i dont live far from sale either.
bigup
PostPosted: Sun Jul 31, 2011 12:15 pm Up
PugJH wrote:
2003 = mulitplexed.
Wheels straight
thanks, i will try this tomorrow Smile
shell-vt
PostPosted: Tue Aug 02, 2011 10:51 am Up
Trade Rating: +46
awkward still on with mine
york 16,3
bigup
PostPosted: Tue Aug 09, 2011 3:54 am Up
received a wheel today (thanks shell!)
and im stuck! putting a screw driver into the hole does nothing
do i have to press the little bar inside down hard
bigup
PostPosted: Tue Aug 09, 2011 4:27 pm Up
anyone?
