Posted: Fri Jul 22, 2011 7:44 am |
I jumped the the car earlyer the day and noticed it was shaking alot more than normal any body have any ideas what that could be? i know its not a lot of info but all i done was start the car and it satrted to shake quite bad!
It was low on oil but i toped it up yesterday if that helps!
Posted: Fri Jul 22, 2011 7:56 am |
Trade Rating: +46
engine mounts
Posted: Fri Jul 22, 2011 8:03 am |
im so happy to here you say that mate cheers all sorts where going through my mind!
Posted: Fri Jul 22, 2011 8:21 am |
shell-vt wrote: |
engine mounts |
Complete guesswork? There are many more common reasons for the EW10 engine to be running lumpy. Things a such as dodgy coilpacks, any number of sensors, hydraulic lifters, VVT problems etc.
Worn engine mounts will result in clunks and bangs as well. I've not ever heard of worn mounts being a problem.
Posted: Fri Jul 22, 2011 8:50 am |
idle control valve? might need cleaned
Posted: Fri Jul 22, 2011 8:54 am |
idle control valve = solution to everything!
Posted: Fri Jul 22, 2011 8:56 am |
Just a shame the 180 doesn't have one! The motorised throttle body controls the idle.
Dodgy ICV wouldn't make it shake quickly either. It would just struggle to run at all.
Posted: Fri Jul 22, 2011 9:09 am |
ah didnt know they didnt have one my bad
Posted: Fri Jul 22, 2011 10:02 am |
cheers Edward im gonna get here booked in to the garage next week ill let them have a look! cheers mate!
Oh and Harty where about in west lothian u from? im origanaily from uphall!
Posted: Fri Jul 22, 2011 10:33 am |
lol i'm living in uphall right now
near enough 10 years now
Posted: Fri Jul 22, 2011 11:03 am |
i must give you a shout the next time im down your way! whats your name? might of heard of you! Im Rikki Smith
