Latest: SA01
Overall: 17138
Online Now [105]:
Visitors: 104
Today: 71468
Total: 112295667
Forums › The Car › 206 Problems › GTi 180 problems
GTi 180 problems
Big_Rich180
PostPosted: Tue Jan 25, 2011 6:52 am Up
Hey guys,
I set of to work this morning and everything was fine until i tried to set of from a juntion, at this point the ABS fault warning came on then a few seconds later it said it had a fault with the cat then the engine light came on and every other light on the dash.....then a few seconds later the engine sounded like a 1 cylinder broke old lawnmower it also had hardly any power, so i got it to work only using 1st gear parked it up left it for 5 mins, came back out and looked under the bonnet, everything seemed fine so i started it and it was all ok Rolling Eyes
Any ideas on what could have happened?
Sorry for the essay Laughing
PostPosted: Tue Jan 25, 2011 7:02 am Up
Doesn't sound good Rich.
Hope its a simple fix.
Big_Rich180
PostPosted: Tue Jan 25, 2011 7:04 am Up
No it doesnt worst thing is is im trading it in on Monday, just need it to last until then.
smiddies
PostPosted: Tue Jan 25, 2011 7:31 am Up
Maybe its a sign???
JamieM
PostPosted: Tue Jan 25, 2011 7:38 am Up
Don't use it until Monday, give it a little V power, and clean the TB lol
Aegean Blue 206 GTi180
dturbopeck
PostPosted: Tue Jan 25, 2011 7:39 am Up
check alternator charge, if its overcharging it can make a car do funny things.
Spanerman
PostPosted: Tue Jan 25, 2011 7:53 am Up
Check the earths too
Sam.
Hello
NICKST
PostPosted: Tue Jan 25, 2011 8:09 am Up
Clean the map sensor have to do mine every now and again.
giveitsomebar
PostPosted: Tue Jan 25, 2011 8:18 am Up
yeah check battery , alternator , earths then come back to us!
Big_Rich180
PostPosted: Tue Jan 25, 2011 8:48 am Up
Cheers guys, i will try all of the above, but in im not going to be using it until i p/x the car in now.
The only fault which has stayed with the car now is an anti pollution fault, when i had this last time it was the wiring to the vvt solenoid, so i will also check that again.
Antix
PostPosted: Tue Jan 25, 2011 9:21 am Up
Custom - Red Stars
Sounds like your 180 is teaching you a lesson for p/x'ing it Wink
It won't go without a fight Twisted Evil
Did you ever watch 'Christine' btw? Laughing
Big_Rich180
PostPosted: Tue Jan 25, 2011 9:30 am Up
Its never stopped teaching me a lesson Laughing
Christine........showing your age again ant Wink
sahdra
PostPosted: Fri Jul 22, 2011 5:54 am Up
How do you do this? seems like mine could do with a bit of this Sad
Black GTi 180/SP pack
