Latest: SA01
Overall: 17138
Online Now [450]:
Visitors: 449
Today: 30668
Total: 112255108
Forums › The Car › 206 Problems › Vibrates when clutch is engaged
karimali831
PostPosted: Fri Jul 22, 2011 3:43 pm Up
After a visit to the garage the mechanics tested if engine mounts was the cause of this and said it was not. They said it had to do something with the rear can anyone tell me what he is on about? I rather buy parts online and pay for labour only at garage, I have to visit again as they didn't know the exact cause and neither do I obviously.
I try explain again...
The slower I engage clutch to biting point the less it judders, quicker I engage biting point the worce it judders/vibrates.
Thanks for any advice please, time to get this sorted it's horrible. Sad
206 GTI 180
gaffy
PostPosted: Fri Jul 22, 2011 5:02 pm Up
sounds like the thrust bearing in the clutch is on its way out fella, got no idea why they think it has to do with the rear ??
chin up lad
karimali831
PostPosted: Fri Jul 22, 2011 5:40 pm Up
Should this get it fixed if it is clutch bearing?
cgi.ebay.co.uk/ws/eBay...917wt_1249
Any ideas how much garages will charge to get it replaced?
What about the clutch plate?
Thanks Smile
206 GTI 180
PostPosted: Fri Jul 22, 2011 5:43 pm Up
anything related to the clutch will be 4 hour labour cost
PostPosted: Fri Jul 22, 2011 5:50 pm Up
Ive been quoted £300 + vat for a new clutch and 4 hours labour today. Sounds similar to mine with the vibrating, mine was the release baring though.
karimali831
PostPosted: Fri Jul 22, 2011 6:08 pm Up
So a whole new clutch just for thrust bearing? I don't know much about clutches but why is it when a part of a clutch does not function or work you need a whole new clutch kit...
206 GTI 180
PostPosted: Sat Jul 23, 2011 2:45 am Up
for a good clutch kit and under normal usage i have yet to see any part of the clutch failed before the friction plate.
roberto.f
PostPosted: Sat Jul 23, 2011 3:17 am Up
I had my clutch replaced and it went away for like a day. Turns out my flywheel needed skimming.
Jun 09 - Nov 09: Peugeot 106 1.1 Independence
Nov 09 - January 10: Vauxhall Astra 1.6 8v Club
January 10 - June 10: Peugeot 206 1.4 GLX
June 10 - Present: Peugeot 206 2.0 GTi
DeadEyePaul
PostPosted: Sat Jul 23, 2011 5:15 am Up
The time taken to dismantle it and replace a part would cost you more than a new clutch kit
