Latest: sparrowdclxvi
Overall: 17139
Online Now [89]:
Visitors: 88
Today: 16436
Total: 113429116
Forums › The Car › 206 Problems › Will my car fail M.O.T?
celts1888
PostPosted: Sun Jul 24, 2011 4:37 am Up
Bought a 206 1.4 lx and it has a de badged boot and no boot handle, i have to pull a cable tie from inside to open the boot, will i need to have this fixed before the M.O.T and what can i do to fix it?
PostPosted: Sun Jul 24, 2011 4:58 am Up
Method of Inspection
Load Security 1. Check that any bootlid, tailgate, loading door, access panel, hinged tailboard or dropside is or can be secured in the closed position.
Reason for rejection
Load Security 1. A bootlid, tailgate, loading door, access panel, hinged tailboard or dropside cannot be secured in the closed position.
macj
PostPosted: Sun Jul 24, 2011 5:12 am Up
No it wont fail.... it is secure when closed... you only need to pull the cable tie to open it
snowonfire
PostPosted: Wed Jul 27, 2011 2:12 pm Up
You need to be able to open it from the outside though, dummy it up for the mot and have a peice of string hanging out to pull...
I used a cable tie as they tent not to snap.
00budham00
PostPosted: Wed Jul 27, 2011 2:38 pm Up
Crap mod ! Asking for trouble as it's not been done correctly ! Get some poppers "solenoids" Fitted
PostPosted: Wed Jul 27, 2011 2:56 pm Up
What do you mean no boot handle?
I don't understand, the boot closes by a little catch on the bottom. As long as this catch is there it won't fail pretty sure opening the boot isn't required to pass the mot just impractical.
