Posted: Thu Jul 28, 2011 6:38 am |
ive read how to do the BSI switch off
but how do i take off the steering wheel and the com2000 from a 2003 1.4HDI?
any guides? ive done a search too!
thanks
| 2003 206 1.4 HDi Style 3 Door | |
Posted: Thu Jul 28, 2011 6:46 am |
bigup wrote: |
thanks |
Searched www.206info.co.uk/Foru...wheel.html
Posted: Thu Jul 28, 2011 6:50 am |
2003 will be multiplexed though Paul, anyone know how different the steering wheel removal is from preplex to multiplex?
| Tivoli LX 1.1
Black GTI 180
White VXR Burg | |
Posted: Thu Jul 28, 2011 6:52 am |
I assume you just have to follow the correct BSI disconnect battery procedure
Posted: Thu Jul 28, 2011 6:58 am |
Lewis wrote: |
2003 will be multiplexed though Paul, anyone know how different the steering wheel removal is from preplex to multiplex? |
Look at the rear of the steering wheel, 2 holes, one on each side. The airbag is clipped in. Push the wire clips in with a screwdriver and carefully pull off airbag. (Disconnect the battery first and follow the BSI reset procedure)
Then there is IIRC a 22mm nut to undo and the steering wheel pulls off.
Posted: Thu Jul 28, 2011 7:51 am |
Trade Rating: +45
Its a torx (star shape) bit but not sure what size
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK  | |
Posted: Thu Jul 28, 2011 8:03 am |
I can do for people who need it removed or help.
I have done it numberous time with new com2000 unit.
I noticed your in manchester. I am around manchester this weekend for awesome gti show :D, its VAG show
Plus My girlfriend lives in sale.
Posted: Thu Jul 28, 2011 8:07 am |
2003 = mulitplexed.
Wheels straight
BSI shutdown. open window, remove battery cables, wait, push a screwdriver into hole underneath, airbag pops off, unclip all plugs, undo airbag,, unscrew bolt in middle of the steering wheel halfway, wack one side of the wheel to pop it off then pull towards you, then fully undo the bolt and remove, then pull the wheel off without smacking yourself, the com2000 unit is attached with 2 - 4 plugs, remove these then lift the flips that hold it to the steering wheel rack, slide off, then swap and reverse.
| WIP: Black 1.6 16v XSi
Beauté Noire | |
Posted: Sun Jul 31, 2011 12:14 pm |
Guy wrote: |
Plus My girlfriend lives in sale. |
ive only just seen your message mate! sorry, it would of been ideal too, i dont live far from sale either.
Posted: Sun Jul 31, 2011 12:15 pm |
PugJH wrote: |
2003 = mulitplexed.
Wheels straight
BSI shutdown. open window, remove battery cables, wait, push a screwdriver into hole underneath, airbag pops off, unclip all plugs, undo airbag,, unscrew bolt in middle of the steering wheel halfway, wack one side of the wheel to pop it off then pull towards you, then fully undo the bolt and remove, then pull the wheel off without smacking yourself, the com2000 unit is attached with 2 - 4 plugs, remove these then lift the flips that hold it to the steering wheel rack, slide off, then swap and reverse. |
thanks, i will try this tomorrow
Posted: Tue Aug 02, 2011 10:51 am |
Trade Rating: +46
awkward still on with mine
Posted: Tue Aug 09, 2011 3:54 am |
received a wheel today (thanks shell!)
and im stuck! putting a screw driver into the hole does nothing
do i have to press the little bar inside down hard
Posted: Tue Aug 09, 2011 4:27 pm |
anyone?
