Latest: DanDan17
Overall: 17128
Online Now [197]:
Visitors: 196
Today: 39520
Total: 100600187
Forums › The Car › 206 Problems › gti 180 engine mount
Chris180
PostPosted: Wed Jul 27, 2011 11:34 am Up
i have been told i need to replace the engine mount in my 180, it is the one below the ECU,
does anyone know a part number for this from a pug dealer as when i got my gf to call up to order one they told her there was 7 to choose from and didn't know which one went under the ECU
2003 aegan blue gti 180 - CatCams 804's camshafts - CatCams vernier pulley - R.S.Tuning remap
Gti 180 Project Thread
Jamie
PostPosted: Wed Jul 27, 2011 1:02 pm Up
Get an upgraded one from VibraTechnics mate. Failing that get a much cheaper one from BakerBM and then bodge it to fit (it is made for a 205 but perfectly fits if you chop some of the thread off)
Chris180
PostPosted: Wed Jul 27, 2011 1:27 pm Up
i was told to avoid the uprated ones as there too stiff??
if i was to get them would it be best to change the whole lot though?
PostPosted: Wed Jul 27, 2011 2:34 pm Up
You shouldn't fit one uprated mount, the others will happily be flexing away and the uprated one will be under a lot of stress.
