Forums › The Car › 206 Problems › date and time dash isnt working |
Posted: Sat Jul 30, 2011 9:15 am |
Hi all, brought a 206 yday.
the screen which should have the date and time on isnt working, no lights no nothing...
i have checked the fuses which i think is for them and they seem fine?
any suggestions
cheers
callum
| Carbon Wrap did look good, untill the chavs in there 1L corsa's and saxo's start doing it.....same story as Lacoste and Stone island, Now its takky! | |
Posted: Sat Jul 30, 2011 9:17 am |
Bulb?
Posted: Sat Jul 30, 2011 9:44 am |
It's either a fuse blown, I would double check as I missed the blown fuse first time I checked, and new bulbs, depending which display it is it will either have 3 or 4 bulbs, or the connection has come loose, pull the top plastic cover off and there's 2 torx screws, undo them and it will just pull out, check the connection on the back
