Latest: SA01
Overall: 17138
Online Now [219]:
Visitors: 218
Today: 13563
Total: 112352063
Forums › The Car › 206 Talk › Temperature gauge permanently at red!!!!!
gillette
PostPosted: Sat Jul 30, 2011 6:58 am Up
Having a nightmare with my 206. Only bought it six months ago an its costing a fortune.
Would really appreciate some help with the most recent problem Sad
The temperature gauge is permanently at red as soon as the key is in the ignition, the fan automatically comes on and continues to run for a short while after the key is removed. I have fitted a new radiator, thermostat, temperature sensor, temperature switch, low speed & high speed fan relays and fan resistor. I have run out of ideas!!!
There was 12V put thru the temperature sensor cables - would this have damaged the ECU or temperature gauge???? Confused
sx206
PostPosted: Sat Jul 30, 2011 7:11 am Up
had something similar going on a while back,turned out to be earth strap to gearbox iirc.worth a check.good luck.
206
gillette
PostPosted: Sat Jul 30, 2011 7:16 am Up
onThanks will have a look. Just worried the ECU has been damaged.
PostPosted: Sat Jul 30, 2011 7:18 am Up
Why not just get it code read instead of replacing parts
PostPosted: Sat Jul 30, 2011 10:51 am Up
What He Said is the best thing to do,and much cheaper than buying parts you don't need in the first place Wink
gillette
PostPosted: Fri Aug 05, 2011 12:22 pm Up
yep had that done - it just says there's a fault in the coolin system! Confused Sad
DSB
PostPosted: Fri Aug 05, 2011 12:42 pm Up
And did you test the parts before replacing them?
