Latest: heikkisj
Overall: 17126
Online Now [71]:
Visitors: 70
Today: 7462
Total: 100380220
Forums › The Car › 206 Problems › Milage Display - No light being displayed
weller96c
PostPosted: Sat Jul 30, 2011 12:47 pm Up
Hello,
I have recently replaced my speedo clocks as my MPH needle stopped working, this is now fixed however the new clocks I have, the mileage display is blank, the bulb/led doesn't appear to amit any light,
All other lights are displayed IE handbreak on, fog lights, etc. I know these are the white bulbs at the rear of the cluster but the mileage doesn't appear to have a replacable bulb.
Does anyone have any ideas, or had to replace one themselves, or know where to start.
Hope that all makes sense and appreciate any and all advice surgestions offered.
Thanks in advance
Chris Smile
PostPosted: Sat Jul 30, 2011 1:00 pm Up
well it's not necessary to be bulbs,sometimes the same LCD of the milage gets faulty,like the data cable is faulty or the same screen,someone will correct me if I'm wrong,but check if there is bulbs first that can be replaced.(it will be a hard task)
DREWDEN
PostPosted: Sat Jul 30, 2011 3:25 pm Up
Is your mileage display second hand ie scrapyard.
If it is i think the mileage has to be lower for it work in your car, it then programmes in to the correct mileage.
can't you just swap over the original.
206 2ltr Hdi glx 53 plate
PostPosted: Sat Jul 30, 2011 3:32 pm Up
You can, it just changes the mileage if it's higher (or lower if it's preplex)
Is your MFD still working?
DREWDEN
PostPosted: Sat Jul 30, 2011 3:41 pm Up
DREWDEN
PostPosted: Sat Jul 30, 2011 3:49 pm Up
SORRY didn't mean to post twice, first one didn't appear to be sent, happened today someone else he sent three.
weller96c
PostPosted: Sun Jul 31, 2011 10:45 am Up
Hi all,
Thanks for all the input it's really appreciated.
Here's the update:
I saw yesterday the mileage display is present just so faint you'd hardly see it, I found that my milage does actually have a bulb (i'm pretty sure it's the milage display bulb anyway)
I replaced the bulb with the one from my old clocks which worked fine. Still the same result, I swapped my old speedo back and oddly the milage is now having the same symptoms, very very faint almost unreadble
Previously the milage display had been find on the old clocks. Can't figure this out at all.
Anyone heard of this problem at all or can advise?
Thanks again
Chris
PS this info might be of use or it may not but thought i'd better share
When my old speedo broke it was the MPH needle. It would jump all around the place, Common fault it seems, Anyway I picked up a speedo clock from a scrappers but it was an old style 3 clock display which didn't have the rev counter.
I stuck with it knowing i'd eventually replace it. Also the 3 clock display had it's mileage stored on the clock rather than my old broken one which pulled the milage from the on board EDU chip
I don't know if this helps at all but this is the background to where i'm at currently. Thanks
Weller96c
