Forums › The Car › 206 Problems › Gearbox whines in all gears, when de-accelerate |
Posted: Sun Aug 07, 2011 3:45 am |
Hi,
The gearbox in my car whines when you de-accelerate, first it started in 5th and now mostly in all gears.
We found metal filings in the gearbox oil.
Ive recently had the clutch release bearing and clutch changed.
Someone has told me that it may well could be a input shaft bearing, that has gone.
Would it be better to just replace the gearbox? and maybe source one from a scrappy.
Thanks for your help.
Cheers,
Posted: Sun Aug 07, 2011 4:00 am |
Trade Rating: +46
cheaper changing g-box if you can get a reliable one
Posted: Sun Aug 07, 2011 9:21 am |
Trade Rating: +13
i had this when i first got my 206, the problem was the gearbox, it had a hole is the case of the gearbox. give it a check.
