Latest: Andyblue64
Overall: 17123
Online Now [146]:
Visitors: 145
Today: 4582
Total: 98628008
Forums › The Car › Request a how-to › help with lights
help with lights
Forum IndexRequest a how-to
chief93
PostPosted: Tue Aug 16, 2011 3:06 pm Reply with quote Up
i was replacing my sidelights and like an idiot i managed to drop one into my actual headlight. its dropped right to the bottom how do i get it back out? cheers
1.6 Xsi - Work in Progress!
"If it has wheels or a skirt, it's gonna give you problems."
PostPosted: Tue Aug 16, 2011 3:07 pm Reply with quote Up
a friend of mine did this and to get it out he had to cut a decent sized hole underneath the light to allow it to drop out, he then just replaced the gap with a plastic strip and lots of tape
iainlovatt
PostPosted: Tue Aug 16, 2011 3:09 pm Reply with quote Up
if its a sidelight just take out the whole light and shake! Smile
(My Garage)
PostPosted: Tue Aug 16, 2011 3:10 pm Reply with quote Up
my friend was not as fortunate, his got jammed lmfao
chief93
PostPosted: Tue Aug 16, 2011 3:17 pm Reply with quote Up
yh i'll just do that then. cheers
It's no big deal if you leave it in.
PostPosted: Tue Aug 16, 2011 3:18 pm Reply with quote Up
Icetto
PostPosted: Tue Aug 16, 2011 4:18 pm Reply with quote Up
This happened to me many times when I had the OEM headlights. The safest way would be to take the headlight out and shake till the sidelight comes out. But I know that might take some time.
Then I got a long piece of flexible wire, fold it so it can go through the sidelight hole easy and put some good presstick at the end of the wire. Try and get the sidelight to stick to the presstick or try and work the sidelight up to hole in the corner
  Quick Reply
Username:
Message:
Quote the last message
