Forums › The Car › 206 Problems › fan and temperature |
Posted: Sat Aug 06, 2011 4:08 am |
I know there is a slow speed and fast speed.What temperatures should the slow speed come on,and what temp should the fast come on.I ask this because when i put air con on the fan doesnt spin but the aircon works,also the fan kicks in about 95 and then drops temp to 90(is this the slow speed)?Thanks
Posted: Sat Aug 06, 2011 4:11 am |
my fan does come on when I put my aircon on regardless of temp,
at 93 degrees my fan comes on and goes off when the temp reaches just under 90, its a 1.4 petrol. sorry I cant help more
Any work you undertake as a result of my posts is done so at your own risk | |
Posted: Sat Aug 06, 2011 4:33 am |
Fan should spin whenever the air conditioning is switched on.
