Latest: heikkisj
Overall: 17126
Online Now [143]:
Visitors: 142
Today: 6075
Total: 100315485
Forums › The Car › 206 Problems › Real wheel bearings!
Twidly
PostPosted: Sat Aug 06, 2011 5:01 am Up
So they're both going majorly... makes for a nice quiet journey!
Will this be ok? Ebay!
They've got some on AEP Direct, but they're £30 each, so you can see the attraction to eBay.
Also, are they difficult to fit? Or basically the same as the front?
Cheers
PostPosted: Sat Aug 06, 2011 5:24 am Up
I can see the ebay attraction, but worth paying that bit extra for the quality, last thing you want is for the bearing to collapse.
They are fairly easy to fit. You may have to make an improvised bearing puller with a long bolt with nuts and washers, socket and piece of decent gauge metal, but apart from that shouldn't have a problem.
Teebag
PostPosted: Sat Aug 06, 2011 5:42 am Up
why not change the rear beam. will be easier and cheaper
my garage inc mod list:
- Antix
PostPosted: Sat Aug 06, 2011 5:46 am Up
why change the beam if he only want to change the wheel bearing?
whee, bearing is dead easy to change Laughing
PostPosted: Sat Aug 06, 2011 5:48 am Up
Change an entire beam just for the sake of a wheel bearing?
It's only about an hours work tops to do both sides.
Twidly
PostPosted: Sat Aug 06, 2011 6:53 am Up
Hmm I may have to consult my finances and go with AEP. But also got an MOT this month and a service... What is about everything coming at once?! lol!
Definitely not changing the entire beam, isn't that like a s**t load of money?
Seabrook: She btw Wink
PostPosted: Sat Aug 06, 2011 7:31 am Up
You might be able to get SKF or similar from a local motor factors. If bearing is showing excessive wear, you'll need it changing for the MOT anyway.
namgaj
PostPosted: Sat Aug 06, 2011 8:13 am Up
I need to do my rears too, did the fronts a few weeks ago= £270 bought 2 complete front hubs LOL
4.0 V8 S-Type Jaguar
