Online Now [95]:
Visitors: 94
Today: 44120
Total: 117607705
Forums › The Car › 206 Problems › ABS Fault 2002 1.6 Auto
smileysue
PostPosted: Thu Aug 11, 2011 9:04 am Up
Hi, 2002 206cc 1.6 Auto
I have a ABS light on the speedo display and the radio/clock display with a warning beep when going over 25mph. how do i know if its the front/rear left/right,cv rings or sensor.
if its a case of taking it and having the system scanned to identify the problem point is there anyone who will do this cheaper than a peugeot dealer.
I am in Sheffield, S25 area. Cheers guys. Shocked
Its the first post i have done, if i didnt do it right or not give the correct information please let me know and i will update post as required
I Hate Monday Mornings
PostPosted: Thu Aug 11, 2011 9:10 am Up
Check the toothed rings on each front driveshaft as they can crack.
If the rings are ok then its scan time.
If it is a sensor gone down then Peugeot main dealer for a new one as there shockingly cheap Thumbs Up
Shefield is a bonus for you, if it needs scanning then PM Lee on here as he has Peugeot Planet Wink
PostPosted: Thu Aug 11, 2011 11:22 am Up
Hi,
I can come code read the car for you.
Where abouts are you as I live in the S25 area
