Latest: heikkisj
Overall: 17126
Online Now [58]:
Visitors: 57
Today: 12938
Total: 100385670
Forums › The Car › 206 Problems › clutch or slave cylinder
novatron1_2
PostPosted: Mon Aug 15, 2011 5:28 pm Up
I had the clutch changed on my DW8 diesel 206 about three years ago, since then I've done ~40K mostly motorway miles, I've noticed in the last couple of days the clutch has started to slip mostly in high gears.
I've done some searching on here and the net and some people are saying it could be the slave cylinder. How do I check the cylinder? I'm thinking about changing the clutch myself this time and I don't want to go to all the hassle to discover I've changed the wrong part!
206 1.9D, 210,000 now dead following failed submarine experiment (flood)
novatron1_2
PostPosted: Mon Aug 15, 2011 5:38 pm Up
meant to add I'm not getting any burning smells
mattievrs
PostPosted: Mon Aug 15, 2011 6:03 pm Up
is it slipping under load?
NO LONGER ACTIVE ON THE FORUM
PostPosted: Mon Aug 15, 2011 6:33 pm Up
Clutch needs replacing.
