Online Now [818]:
Visitors: 817
Today: 178194
Total: 149790679
Forums › The Car › 206 Problems › Please HELP with fuse problem>>F5 also does the job of F18??
Go to page Previous  1, 2
PostPosted: Sat Aug 20, 2011 5:40 am Up
206DAG wrote:
any idea why when i removed fuse 5 in engine bay my lights for my dials, rear reg plate and ashtray dont light up when these are supposed to be on fuse 18 under steering column, i have a pre plexed 206, thanks. Debs
Where do you think fuse 18 in the cabin fuse box gets its electrical supply from Wink
The answer is in your question Laughing
mdstone
PostPosted: Sun Aug 21, 2011 4:21 am Up
If you had the same problem as me where the horn fuse would blow all the time (or putting in a higher amp fuse made it sound constantly (which is a bad idea by the way)) then you probably need an ECU update to the latest version. I had this anoying problem for months and I'd often be driving without a working horn. I had enough of this and local garages could not find the fault so took it to Pug. They updated to the latest version of the ECU software and never had a problem since. Known fault apparently!
Btw, this usually happened when unlocking the car. Could be different to your fault though.
Peugeot 206 GTi
Page 2 of 2
