Latest: S2cgm
Overall: 17178
Online Now [333]:
Visitors: 333
Today: 22920
Total: 136879070
Forums › The Car › 206 Talk › Should i keep it or sell it
LilLew
PostPosted: Sun Aug 21, 2011 3:09 pm Up
Hi all
I am back finally decided to start the work on my pug after it failed its MOT on the rear axle bearing ive just spent two weeks splitting my axle and after hitting my hand with the sledge i finally got the passenger torsion bar out of the axle as i only need to change one side (inner and outer bearing and dust seal)
my only thing now is everyone is saying mot the car and sell it because i have only had the car 1 year and the repair list is as follows
clutch
hand brakes cables (Both)
Top sus mounts (Both)
Wishbones (Both)
track rod ends (Both)
Drop links (Both)
Rear exhaust box
Brake pads (Wear & Tear)
All Discs (Wear & Tear)
Lambda Sensor (Front and rear)
Abs Sensors (Front & rear Drivers side)
Radiator (plymouth rads)
Lower radiator pipes (From Dealer)
And this is in one year
Things to still do
renew rear cailpers
axle bearing
passenger seat does not recline
sort oil leak
replace exhaust rubbers
REMOT
i am in two minds to keep for sell it does still have finance out on the car if i was to sell i am still willing to pay it
2003 Pug 206 2.0 GTI 180
-Dave-
PostPosted: Sun Aug 21, 2011 3:12 pm Up
Trade Rating: +36
You will need to check with your finance company as technically you don't own the car. You might be able to trade it in if you got extra finance with them though.
Ex 206 Owner.
What else would need doing once you have dine all that? Wink better the devil you know and all thst
ukskater01
Tbh it's up to you, I would keep seen as you've done soo much work to it, at least you know the things you've fixed shouldn't go wrong again Wink
LilLew
PostPosted: Sun Aug 21, 2011 3:18 pm Up
lmao yer should not but my luck it will fall apart the mx5 i just got has died the coil pack is knackered and it is sat about 100 meters away from my pug now lol outside my mums house
i just have a feeling that the next big thing to go would be the engine and i really cant afford to replace that lol
L5_UKS
PostPosted: Sun Aug 21, 2011 3:31 pm Up
Yeah id keep it as you could go out and buy a new car and it still have problems and go though it all again, Most second hand cars have problems.
00budham00
PostPosted: Sun Aug 21, 2011 3:37 pm Up
That's not that bad !!! Youve started it may as well follow through and it will last you !
PostPosted: Sun Aug 21, 2011 5:32 pm Up
As long as you keep on top of servicing the shell will rust away before the engine goes kaput.
LilLew
PostPosted: Mon Aug 22, 2011 2:38 am Up
i am thinking that what else can go wrong tbh but am just gettin fed up with always repairing it loli know as soon as i drive it i will love it again
