Posted: Wed Aug 24, 2011 1:25 pm |
Hi,
I have a 2005 1.4 hdi. Every once in a while, the engine management light comes on. If I then go over 3000 revs, I lose power. After a couple of days, the light then goes off and the car runs as normal.
it's not a big issue as it's still driveable below 3000 revs, just annoying. It can go for weeks before the light comes back on.
Any ideas appreciated
Gary
Posted: Wed Aug 24, 2011 1:32 pm |
EML comes on for a reason get it checked.
It won't gove over 3k revs as that is 'Limp Mode'.
Tke it to a garage and get the codes read.
Posted: Wed Aug 24, 2011 1:51 pm |
Had the same issue, air intake had come out behind the engine so it couldnt get enough through the maf sensor, check all along the pipe from the end upto behind the block
Cheers Tom,
It doesn't seem serious as it resets after a day or so but I will play it safe and pop it down to my local Pug dealer tomorrow
Results to follow ....
Posted: Wed Aug 24, 2011 1:52 pm |
jimblonduk wrote: |
Cheers Tom,
Results to follow .... |
check what i said first, best to give it a once over before paying the £50 labour or whatever they will charge you lol
Posted: Wed Aug 24, 2011 1:55 pm |
Antknee wrote: |
jimblonduk wrote: |
Cheers Tom,
check what i said first, best to give it a once over before paying the £50 labour or whatever they will charge you lol |
You still suck on your mums boobs so you have no right to comment Your WRONG!
Posted: Wed Aug 24, 2011 1:57 pm |
i think you will find breast feeding is perfectly normal and healthy! FANKS!
Posted: Wed Aug 24, 2011 1:58 pm |
BITTY!!!
Antknee wrote: |
Had the same issue, air intake had come out behind the engine so it couldnt get enough through the maf sensor, check all along the pipe from the end upto behind the block |
does that mean I gotta open my manual?? FFS
ok, will do
Posted: Wed Aug 24, 2011 2:02 pm |
nahh just look along the intake pipe and look if any have come out of where they should be or if there are any splits in the pipe, you dont have to take anythin apart haha
Posted: Fri Sep 02, 2011 4:04 pm |
I have had this problem twice since having my HDI. Both times it's been the air filter, easy to check, take it out and see if the problem goes away. If it does a good few taps against a wall will clear the filter sufficiently, a new one is only a few quid though.
| 206 HDI Urban 55 Plate, 206cc 52 Plate | |
