Posted: Thu Aug 25, 2011 3:07 am |
Trying to remove the interior trim and i can't see how the plastic trim covering the top fitting part of the seatbelt comes off, also can't see how to remove the top mounting pioint for the seatbelt.
| new to the whole peugeot thing! | |
Posted: Thu Aug 25, 2011 4:01 am |
Do you mean the pillars? They just pull off get a screwdriver under them. Just metal clips holding them in.
Posted: Thu Aug 25, 2011 4:59 am |
Seatbelt on the A pillar rob?
See the adjustment lever for seatbelt height? Pull. Hard. 13mm bolt underneath IIRC.
Posted: Thu Aug 25, 2011 6:17 am |
Posted: Thu Aug 25, 2011 7:03 am |
tomd0801754 wrote: |
See the adjustment lever for seatbelt height? Pull. Hard. 13mm bolt underneath IIRC. |
Thought it might be just didn't wanna break anything.
Posted: Thu Aug 25, 2011 8:50 am |
For anyone trying to remove the seatbelt height adjuster don't just pull hard on it, well not unless you want it to snap in half. Suppose I mmanaged to get the trim off but now need a new seatbelt adjuster.
Posted: Thu Aug 25, 2011 11:53 am |
Oh I forgot about that. The rest pull off haha. Thanks for the info on removing it anyway I might need it if you remember to look in your inbox
