Latest: Kifi69
Overall: 17183
Online Now [582]:
Visitors: 581
Today: 125988
Total: 143965965
Forums › The Car › 206 Problems › Coolant look normal or oil contamination?
jramsden91
PostPosted: Fri May 25, 2018 7:47 am Up
Hey
Is this normal for coolant or do you think it has been contaminated with oil?
Also looks like there's been contamination of the timing belt cover. Engine was making a weird intermittent squeal which I though may have been water pump, but guess it could be oil on the timing belt!
Not got the classic mayo, and engine oil looks normal to me, but could be a blown head gasket I suppose.
Thanks for any advice!
PostPosted: Fri May 25, 2018 5:30 pm Up
Looks like rust in the tank, nothing to worry about. And thats your auxiliary belt, not the timing belt!
owlinbrum
PostPosted: Fri May 25, 2018 9:59 pm Up
Agree with Steve206. A flush and coolant change my be advisable. Keep things from deteriorating. Smile
jramsden91
PostPosted: Sat May 26, 2018 8:35 am Up
Thanks guys.
Steve - I know, just above is the cover for the timing belt though and you can see there's a distinctive line where it changes colour, presumably from a leak.
owlinbrum
PostPosted: Sat May 26, 2018 11:24 am Up
