Posted: Fri Aug 26, 2011 11:29 am |
Hello,
I have noticed an issue with my 180.
Basicaly I can't adjust my wing mirrors.
If I point the thing to the right and try to adjust and both mirrors move in same direction, Anyone ever had this? I can never get it perfect?
I've a feeling its related to the mirrors having the ability to fold in.
Any ideas?
Cheers
Posted: Fri Aug 26, 2011 11:45 am |
Sounds more like a defective mirror switch.
Posted: Fri Aug 26, 2011 1:42 pm |
bashyy1 wrote: |
Any ideas?
As said above, probably the switch.
As a quick work-around until properly resolved, adjust one one side properly, then unplug that mirror (connector behind the tweeter cover) and set the other one, reconnect...
| Silvermetallic 2004 206 RC | |
Posted: Sat Aug 27, 2011 2:14 am |
If your brave / skilled enough you could take the switch apart & give the contacts for the mirror movement a good clean.
Posted: Sat Aug 27, 2011 4:57 am |
Thanks for the advice guys
