Posted: Fri Sep 16, 2011 4:28 pm |
My N/S track rod end is seized, so far I've tried soaking it in WD40 the night before, heating it up with a blow lamp and then throwing cold water on it, clamping the track rod in moles grips and using an axle stand to support this whilst I smack another set of adjustables attached to the track rod end.
So far nothing has managed to shift it, has anyone got any ideas?
I thought about taking it to a garage next time there's a cheap tracking offer on, but last time I tried this with a Punto with a similar problem they told me i needed a new steering rack! (I did manage to free this one using the above steps)
| 206 1.9D, 210,000 now dead following failed submarine experiment (flood) | |
Posted: Fri Sep 16, 2011 4:33 pm |
Penetrating oil?
Posted: Fri Sep 16, 2011 4:39 pm |
| tomd0801754 wrote: |
| Penetrating oil? |
plusgas
Posted: Fri Sep 16, 2011 4:41 pm |
I got some plusgas recently for when I did the clutch change, I might try it overnight
Posted: Fri Sep 16, 2011 4:48 pm |
Try halfords shock and unlock spray, then try to tap other end of the spanner gently to undo the bolt
Posted: Sat Sep 17, 2011 1:18 am |
If all else fails then disconnect it from the hub and carefully use an angle grinder to grind down either side where the threaded portion is but keep checking and be ready to stop the instant you see the first signs of any thread. That'll release most of the tension and then it will unscrew. Takes about 10mins but you'll need a new track rod end so get that first
Posted: Sat Sep 17, 2011 2:27 am |
Hot blue spanner is what you need
Posted: Sat Sep 17, 2011 2:38 am |
If you have heated it already you will need to replace it anyway so I would heat it up as quickly as possible and try the mole grip and adjustables again while its hot.... remember to clean up the thread after
Posted: Sat Sep 17, 2011 3:15 am |
| Deckchair5 wrote: |
If all else fails then disconnect it from the hub and carefully use an angle grinder to grind down either side where the threaded portion is but keep checking and be ready to stop the instant you see the first signs of any thread. That'll release most of the tension and then it will unscrew. Takes about 10mins but you'll need a new track rod end so get that first  |
I had mire replaced last week. The garage had to do the above.
Posted: Sat Sep 17, 2011 5:33 am |
My mechanic friend had to use an angle grider on the nut like others have said go slowly and you should be fine
| You never really learn to swear until you learn to drive | |
