Latest: TigerHunters
Overall: 17144
Online Now [42]:
Visitors: 41
Today: 10594
Total: 115883855
Forums › The Car › 206 Problems › rear door latch help please !
rings1
PostPosted: Sat Sep 03, 2011 9:48 am Up
My rear.door won't open from the inside or out, iv had the door card off and the arms are still attached to the linkages on the latch itsself and iv pressed the linkages by hand and the door still won't open ,any common problems ? And is the latch itselff up the spout ? Is there a way of getting the door open to get to the bolts holding the latch in place Many thanks ben
Y0
rings1
PostPosted: Sat Sep 03, 2011 10:19 am Up
Anyone ?
Y0
jamesmcuk
PostPosted: Sat Sep 03, 2011 2:35 pm Up
if what you say is true then your lock needs replacing - i can scan and post the lock bit of haynes if you need it
