Latest: dreyfalon
Overall: 17121
Online Now [559]:
Visitors: 558
Today: 95829
Total: 97395825
Forums › The Car › 206 Problems › oil leak, spluttering, loss of power?
Davo86
PostPosted: Mon Aug 29, 2011 2:43 pm Up
Hi all, hope someone can help
My 206 has been leaking a small amount of oil for the past few weeks, however in the past few days the leak has become quite large and my car is almost spluttering and losing power when at low revs,
The oil is coming from somewhere near the top of the engine, as it is visible all over just above the oil cap when you remove the engine cover.
Also i should add this car has had 3 head gaskets in 4 years so i'm starting to think there is another underlying issue, each gasket was changed at a different garage and the car is very regularly topped u with coolant,
55reg 206 Sport 1.4 16V
PostPosted: Mon Aug 29, 2011 2:48 pm Up
Head gaskets are a well known fault with the w**ky ET3 engine BUT that issue was cured long before 2005.
Might be an idea to either take it to a Peugeot / Citroen main dealer for a quote to repair OR find a french specalist that knows what there doing.
