Posted: Mon Aug 29, 2011 3:36 pm |
Hi Everyone
Please could someone shine some light on this annoying problem my car has! There is water trapped somewhere in or around the glove box.It doesnt make a noise all the time but sounds like its moving from one place then seeps back over time.Its just like a bottle of water has been left in the car and is rolling around.The garage has tried all the things suggested on here,heater matrix,air locks,cleared out drain holes etc.Also they removed the glove box and the lining under the wheel arch.NOTHING. Where is this water? The mats are not wet and it is not getting any worse.I own a quiksilver 52plate 1.4 3dr. Any suggestions?
Posted: Mon Aug 29, 2011 3:46 pm |
bottle of coke in't glovebox?
Posted: Tue Aug 30, 2011 12:52 am |
Trade Rating: +32
My thoughts would lead me straight to the headgasket.
But as you took it to a garage I presume that they would have checked for this.
Posted: Tue Aug 30, 2011 1:47 am |
Servo
Posted: Tue Aug 30, 2011 2:46 am |
Check the drainage holes in the passenger door too.
Posted: Thu Sep 01, 2011 2:41 pm |
Thanks for all your ideas.Sort of ignored the noise this week! Feel like drilling a few holes in the dash!!
Posted: Thu Sep 01, 2011 2:42 pm |
Easy fix for all interior rattles and noises... turn up the stereo. Works for me.
| new to the whole peugeot thing! | |
Posted: Thu Sep 01, 2011 2:57 pm |
| Ash wrote: |
| Check the drainage holes in the passenger door too. |
Yes this is the first thing I would check too
Posted: Fri Sep 30, 2011 3:12 pm |
More news on noise!!
Decided it is most likely huge airlock in heater matrix.But was then told the air is probably coming in through head gasket!!! Next idea is to drain the whole system and start again and see how quickly it develops.Is there anyway of checking head gasket? Or would you leave it alone for now? The car is not losing water and the oil is fine.
Posted: Tue Nov 08, 2011 1:12 pm |
I had this noise for about 3 months and ignored it...head gasket went today. I thought it was nothing, I wish i had looked it up before.
Posted: Tue Nov 08, 2011 1:24 pm |
Checked your water level?
Bled the system?
Do basics, then get back to us
| Team Impossible Possible
Posted: Thu Nov 10, 2011 3:03 pm |
I have noticed the same thing on mine in the same place and i do have the exact same car Quiksilver, 52 plate. Sometimes it's there and sometimes it isnt. It sounds like a fair amount of water wherever it is. If you have any joy in finding out what it is please share.
| erm yes i will update this later | |
Posted: Mon Nov 14, 2011 11:51 am |
I have this too,
It seems to only make the water noise upon acceleration. Even in neutral for a good while, whilst it warms up.......... then after it seems to get less and less.
| why wont you work??????????????????? ARGH F**k it!!!!! | |
Posted: Mon Nov 14, 2011 12:26 pm |
Hate to say it but we had this noise, later the car wouldnt start and it was headgasket gone, but it may just be low water or airlock in water system.
Dave
Posted: Tue Nov 15, 2011 7:07 am |
I had this, My turned out to be a radiator leak
Does your coolant go down quick by any chance?
