Online Now [1689]:
Visitors: 1688
Today: 120581
Total: 152161088
Forums › The Car › 206 Problems › Desperately Needed Car Electrician South East
davieboy86
PostPosted: Wed Aug 31, 2011 12:05 pm Up
Was just wondering if there were any car electricians in the south east, kent london anywhere really. having a nightmare trying to sort out my central locking.
Checked all the threads and made several muself about he problem doing my head in completely now.
Had the car at the mechanics today and he wanted to take the dashboard out to check the multi function wiring (lol) because he couldnt find anything wrong with the actuators or any wiring between the door and car. im sure its one of the doors but the interior lighting system works fine, no problem at all so im stuck.
any one near by sold the issue or could help diagnose or point me in the direction who could.
Many thanks
THE_GOOCH
PostPosted: Wed Aug 31, 2011 12:42 pm Up
where abouts in kent are you??
Rob2859
PostPosted: Wed Aug 31, 2011 12:55 pm Up
Try the engine bay fuse box.
THE_GOOCH
PostPosted: Wed Aug 31, 2011 1:13 pm Up
if you have no luck give ENIGMA a call. they are in ashford, kent. 01233 623236. hope this helps
davieboy86
PostPosted: Wed Aug 31, 2011 1:33 pm Up
In near dartford and hextable, I havent checked any fuses, cant imagine there is a fuse some where ive tripped, i hope to god its thhat simple, any idea which to look for ?
PostPosted: Wed Aug 31, 2011 1:36 pm Up
Not working at all, or locks bouncing?
LilLew
PostPosted: Wed Aug 31, 2011 1:41 pm Up
have you done what was mentioned in your other post about replacing the locking solenoid
2003 Pug 206 2.0 GTI 180
davieboy86
PostPosted: Wed Aug 31, 2011 4:04 pm Up
I haven't replaced the solenoid yet, the one at the local scrappy had side damage.
Lee - the locks are bouncing, the mechanic thinks it's the drivers side as when you turn the key in the drivers side or push the popper inside the door it locks fine but doesn't do anything to the other locks, where as when you push the passenger side popper, the locks all bounce up.
I think it's the passenger side as the drivers side always acted independent of the other doors, I'm stuck to be honest, it's not the door sensors I don't think because the interior lights all work fine when the doors open or closed.
PostPosted: Wed Aug 31, 2011 4:16 pm Up
Just replace all the door solieniods?
davieboy86
PostPosted: Wed Aug 31, 2011 4:29 pm Up
Im not sure whether its the solonoid or the locking mechanism ... ....
PostPosted: Wed Aug 31, 2011 4:34 pm Up
Its all one unit.....
kit325
PostPosted: Thu Sep 01, 2011 10:43 am Up
9 out of 10 is the solenoid when u have bouncing lock. Might work out cheaper if u just replace both the locking mechanism (2 doors) from scrappy, then getting urself an electrician.
kit
Deckchair5
PostPosted: Thu Sep 01, 2011 11:17 am Up
The mechanic is right. If you push the internal lock popper down and the other locks don't do anything then that is the problem locking solenoid which you need to change. It's signaling it's open (when it isn't) which commands the others to open immediately
davieboy86
PostPosted: Fri Sep 02, 2011 10:36 am Up
So what your saying is the drivers door popper when pushed SHOULD make the other poppers go down too?
Deckchair have you have experience doingthis in the past, I think a trip to the scrappy tomorrow then.
Deckchair5
PostPosted: Fri Sep 02, 2011 11:34 am Up
That's right
When you get a new solenoid lock push it to the closed position, then disconnect the suspect solenoid connector and attach it to the new one. It should of course make all the other locks copy it and close too. That's an even easier way of testing for a suspect lock
