Latest: dreyfalon
Overall: 17121
Online Now [564]:
Visitors: 563
Today: 71288
Total: 97371288
Forums › The Car › 206 Problems › Desperately Needed Car Electrician South East
Go to page Previous  1, 2
davieboy86
PostPosted: Fri Sep 02, 2011 11:59 am Up
cool, at the scrappy the plan is to look for
- a three door, pre plex, non side damaged door solonoid,
and take the unit out from inside the door card.
From looking inside my door its just the three torx screws in the door shut area, and then disconnect all the white plastic rods inside that do the poppers and inner and outer handle, and leave the lock mechanism in the door, dont want that as it wont match my car (obv.)
Deckchair5
PostPosted: Fri Sep 02, 2011 4:32 pm Up
Good hunting then Davieboy Smile
davieboy86
PostPosted: Fri Sep 02, 2011 4:56 pm Up
will report back after probably ruining the entire system lol
PostPosted: Sat Sep 03, 2011 2:34 am Up
Would it not be better to just buy a new solenoid? Bearing in mind how many 206's have had this over the years I'd buy a new one.
Page 2 of 2
