Online Now [551]:
Visitors: 551
Today: 165305
Total: 149560934
Forums › The Car › 206 Talk › check strap
check strap
Forum Index › 206 Talk
karimali831
PostPosted: Sun Sep 04, 2011 6:19 am Up
Hi,
I've got a problem with check strap, the two bolts won't tighten or loosen so I can't get it out to get it replaced? It will just turn and turn... any ideas to unbolt?
206 GTI 180
eddrj
PostPosted: Sun Sep 04, 2011 6:25 am Up
is the bolt rounded off ? if not getting loose ,
should be easy undo two bolts just make sure you got rite star key torx screwdriver .
Old car 2000/ 206 2.0 hdi.
brad-morris
PostPosted: Sun Sep 04, 2011 6:26 am Up
Cross threaded?
karimali831
PostPosted: Sun Sep 04, 2011 6:36 am Up
brad-morris wrote:
Cross threaded?
Probably, at first it was tightening then just loosened. Now either way it will just turn without feeling it loosen or tighten. Sad
206 GTI 180
