Online Now [355]:
Visitors: 354
Today: 85203
Total: 142706520
Forums › The Car › Request a how-to › how do i remove A B C pillars???? help please
Forum IndexRequest a how-to
plebsone
PostPosted: Sat Dec 11, 2010 9:58 am Reply with quote Up
Plebsone
Uz
PostPosted: Sat Dec 11, 2010 10:03 am Reply with quote Up
A) Front ones just clip out once you've removed the door seals. Unclip the ultrasonics if you've got them.
B) middle ones clip out once you've taken undone the bolts and remove the seatbelts.
C) Rear ones are exactly the same as the middle ones. Remove the seat belts and just unclip.
PostPosted: Sat Dec 11, 2010 10:04 am Reply with quote Up
IIRC the rear ones have two torx bolts in them as well.
rudymason
PostPosted: Tue Aug 30, 2011 3:40 am Reply with quote Up
had a bit of difficulty with the middle seatbelts is there a particular way in which to remove them, as in in a particular order of events ... as i seemed to have gotten rather frustrated within two minutes of doing it and snapped one bit of plastic Razz
EDIT: front seatbelts Razz
  Quick Reply
Username:
Message:
Quote the last message
