Posted: Sun Sep 18, 2011 9:18 am |
Hey guys.
well i stupidly cross threaded my rear hub last year while fitting multi fittment wheels i put the bolts through the wrong holes, DOHHH!!
the wheel is still secure and i check it every week just to make sure.
but im buggerd if i get a puncture or need to get the wheel off!
im wanting to know if its hard to change a rear hub? I would like to do it myself but not sure if it will be easier taking it to a garage instead...
i can do basic things with a car, service, brakes, exhaust fittment etc but i wouldnt have a clue how to do a clutch or timing belt.. just to give an example of how "skilled" i am or am not lol
has anyone done one before??
thanks guys
Posted: Sun Sep 18, 2011 9:28 am |
As easy as changing a wheel bearing
Posted: Sun Sep 18, 2011 10:04 am |
if you got a puller, then the job is done.
probably takes 10 to 15 mins of work.
Posted: Sun Sep 18, 2011 10:27 am |
i havnt got a puller....
might know someone who has though, what exactly is involved...? id imagine taking some bolts out then just pulling the old hub off?
im thinking a garage may be the best idea for me as i need to car everyday and if i balls it up im fooked!!
Posted: Sun Sep 18, 2011 10:40 am |
rear disc off, remove hub cap, unbolt hub nut, pull out the old hub;
new hubs in, tighten up the nut, then put everything back on
Posted: Mon Sep 19, 2011 10:21 am |
hmm ive decided to let a garage do it, they only want £25 if i supply the part lol
will save me some time aswell
thanks for the help though guys
Karl
