Latest: dreyfalon
Overall: 17121
Online Now [535]:
Visitors: 534
Today: 94736
Total: 97394732
Forums › The Car › 206 Problems › Car Alarm
Car Alarm
boyracer93
PostPosted: Tue Sep 06, 2011 5:49 am Up
My car has a alarm button in the center console, but it does nothing and i have no idea how to check if my alarm works or????
cartoonhead
PostPosted: Tue Sep 06, 2011 5:58 am Up
the button is to turn off the interior sensors.
press it down for 2-3 seconds and watch for the red light on the hazard light button, when the light is on your sensors are turned off and when you now lock the car with the fob you could leave the window open but the doors are still alarmed.
if you dont press the button and put your window down arm the alarm and give it a minute or 2 and then go to open window and see if your alarm goes off.
Ali_H
PostPosted: Tue Sep 06, 2011 6:13 am Up
It's the ejector seat button, just make sure you don't press it whilst sat in the passenger seat.
kurtis wrote:
PostPosted: Tue Sep 06, 2011 8:39 am Up
RTFM or look in the forum FAQ Rolling Eyes
www.206info.co.uk/Foru.../t=23.html
Ray140978
PostPosted: Tue Sep 06, 2011 10:27 am Up
Just recently bought a 206 Gti, and has a few issues with it...
One of the issues was the rear boot latch was completely bent and broken so the boot would not lock...
I took this out and replaced with one i managed to forage off of another 206 Gti..
Cut a long story short, when i used to deadlock the car it made a sweet beep to show the alarm was set....but since taking the broken latch out and replacing it, it only deadlocks..no sound whatsoever..
There is a wire that connects to it so assumed this was for the alarm to register the boot was closed..could it be a faulty switch in the latch I have replaced?
206 Gti Owner..
PostPosted: Tue Sep 06, 2011 10:40 am Up
The standard Peugeot factory alarm system SHOULDNT make a noise when you deadlock the car / arm it.
If it beeps on arming the system then either the boot / bonnet or a door isnt shut correctly Wink
Your alarm system is now arming correctly as its not beeping.
Ray140978
PostPosted: Tue Sep 06, 2011 10:44 am Up
Yeah just tried it with the bonnet not secured properly and beeped...but no such luck with the boot open...
many thanks for your prompt reply...
Got a few things more to iron out with this car...will be a while before she is how I want her.
206 Gti Owner..
PostPosted: Tue Sep 06, 2011 12:18 pm Up
Check the switch in the latch is working correctly, brown connector plug nice & secure?
Try the plug disconected & see if it beeps?
Then short the 2 connectors out on the plug & try again - any change?
