Latest: dreyfalon
Overall: 17121
Online Now [422]:
Visitors: 421
Today: 66964
Total: 97470683
Forums › The Car › 206 Problems › Just had her serviced, couple of notes though...
MRyan89
PostPosted: Tue Sep 13, 2011 6:40 am Up
Just had my car serviced and the mechanic wrote up a list of advisories after giving it a check over! Thought I would run it by everyone on here about how much I should be charged to fix the problems as everyones pro on here Very Happy
Its as follows -
1.) Front Lower Arm (Front + Rear) Bushes split
2.) Front drop link arm rubbers perished
3.) Driveshaft seal slight leak
4.) Rear tyre worn inner edge - sounds like ive got a bearing going, could this have caused it?
Cheers for any input!
LilLew
PostPosted: Tue Sep 13, 2011 7:13 am Up
Its as follows -
1.) Front Lower Arm (Front + Rear) Bushes split (My guess replace wishbone)
2.) Front drop link arm rubbers perished (replace droplinks)
3.) Driveshaft seal slight leak (Does he mean cv boot )
4.) Rear tyre worn inner edge - sounds like ive got a bearing going, could this have caused it? (More then likely the bearing are going my 180 did that and i have jus replaced)
2003 Pug 206 2.0 GTI 180
JR180
PostPosted: Tue Sep 13, 2011 8:40 am Up
Front Lower Arms (non OE) are normally around £50-£60 a side.
Drop Link around £15
Driveshaft Seal £pence + labour
Wheel Bearing £50?
I'm a newbie on Peugeot to be honest, but I wouldn't be want to charged more than £300 inc/ labour for that, not including a new tyre!
Bonjour!
MRyan89
PostPosted: Tue Sep 13, 2011 9:01 am Up
Thanks for the rough figure, its mostly just seals and bushes that have gone which makes it more annoying Sad
PostPosted: Wed Sep 14, 2011 3:19 am Up
Wheel Bearing £50?
where can you get the driveshaft seal for pences?
PostPosted: Wed Sep 14, 2011 3:31 am Up
You sure your tyre is correctly inflated and tracking is correct?
