Online Now [539]:
Visitors: 538
Today: 375182
Total: 153773176
Forums › The Car › 206 Talk › Wiring fogs up
Wiring fogs up
Forum Index › 206 Talk
acotton21
PostPosted: Fri Sep 16, 2011 12:15 am Up
just brought a non sport bumper thats come with fogs for my 1.4 51plate and im going to swap them over sometime this weekend, will there be some wires for the fogs already or will i need to be messing around does anyone know?
PostPosted: Fri Sep 16, 2011 2:13 am Up
Peugeot put some extra plugs on the looms, and I have noticed that these vary from model to model.
Without having a look behind your bumper, it would be impossible to say if the connections are already there. If they are, then I would have thought you would need a new stalk/com unit to turn them on and off. f there are no wires, you need to wire them yourself using a switch and a relay.
PostPosted: Fri Sep 16, 2011 3:32 am Up
If you have the wires then you need a new stalk/com plus a new engine fuse box
If you don't then you need a retro fit kit
I'd go with retro anyway, or just use a relay so they come on with main beam
