Latest: eltel666
Overall: 17146
Online Now [86]:
Visitors: 85
Today: 19740
Total: 116156757
Forums › The Car › 206 Problems › HELP PLEASE: 206 Diagnostic
hollypinder
PostPosted: Sat Sep 17, 2011 8:20 am Up
Hi, just wondered if anyone can help, my car has been running lumpy and below power. Engine management light was on. Ran diagnostic on it and it says:
P0420 - Generic - Catalyst Efficiency below threshold (bank 1)
P0202 - Generic - Injector Circuit open - cylinder 2
P0203 - Generic - Injector circuit open - cylinder 3
Any ideas?
Its 2001 1.1 206.
Holly Pinder
cartoonhead
PostPosted: Sat Sep 17, 2011 8:52 am Up
Thanks to lee you can look them up Here
{edit}
my bad , miss read what you put as you allready have what the faults are Wink
i'd say possibly faulty lambda and 2 faulty injectors
PostPosted: Sat Sep 17, 2011 9:15 am Up
Sounds like either:
NGK spark plugs have been fitted.
& / OR
Coil pack has the magic word SAGEM on it.
PostPosted: Sat Sep 17, 2011 9:38 am Up
MrBSI wrote:
Sounds like either:
& / OR
What He Said
And the CAT, just give the car a blast down the lanes when you've sorted the plugs/pack
dumdum0910
PostPosted: Sat Sep 17, 2011 3:49 pm Up
ive got the p0420 code come up on my 206 aswell.. i no my car had a new cat back in jan time, has recently been serviced , ive given it a good blast up and down the motorway to clear it out and still hasnt worked. could it be a lamda problem?
hollypinder
PostPosted: Sat Sep 17, 2011 4:14 pm Up
thanks for your replies i have put new plugs in and 1 new injector and cleared the codes runs a bit better but not much.
Will check the coil pack in the morning as for the lamda diagnostic said its ok so guess it might be the cat thanks for your help.
Holly Pinder
PostPosted: Sat Sep 17, 2011 4:19 pm Up
What plugs?
hollypinder
PostPosted: Sat Sep 17, 2011 4:30 pm Up
not sure just some i had laying around for that car will look in the morning as car and bits not here.
Are ngk that bad and if thats whats in the car could that be doing it or not helping
Holly Pinder
PostPosted: Sat Sep 17, 2011 4:33 pm Up
NGK play havoc with the misfire detection system, and cause premature failure of the coil pack
Bosch only
hollypinder
PostPosted: Sat Sep 17, 2011 4:43 pm Up
ok thanks
Holly Pinder
