Latest: morgan20
Overall: 17135
Online Now [74]:
Visitors: 73
Today: 15185
Total: 110827537
Forums › The Car › 206 Problems › Over heating (iThink)
Gra1n
PostPosted: Mon Sep 26, 2011 5:05 pm Up
my temp gauge goes above 90 right to the top but doesn't go into the red. i'v changed head gaskit, fan works. What do you guys think?
Peugeot 206 Roland Garros 1.6 16v
Pioneer AVH-5300DVD
JL Audio 10W7AE
JL Audio H.O Box
JL Audio 1000/1 V2 --- JL Audio 1/0 Guage Wiring + Fuse Holders
Audison LRX300.4
NSB90 Battery
PostPosted: Mon Sep 26, 2011 5:08 pm Up
Is the fan coming on? should be around 90 degrees
Antknee
coolant topped up? been bled?
kingsway2468
PostPosted: Mon Sep 26, 2011 6:01 pm Up
Try bleeding and feel the top hose when its overheating if it burns you try thermostat if its cold change temp sender
Gra1n
PostPosted: Fri Nov 04, 2011 12:16 pm Up
Changed both senors and the temp gauge still goes very high. Any Suggestions?
Pioneer AVH-5300DVD
JL Audio 10W7AE
JL Audio H.O Box
Audison LRX300.4
NSB90 Battery
Gra1n
PostPosted: Sun Mar 11, 2012 4:13 pm Up
My Car keeps reaching this temp when i switch my car off, does anyone what could be wrong?
Things i'v done so far
- Head gasket
- All temp realted sensors been changed
- Relay corroded connections been cleaned
Basically everything possible, i'm getting really concerned as this is the second time i'm doing the head on my car due it over heating.
I have attached a image so you guys car see
i1218.photobucket.com/...-00005.jpg
Pioneer AVH-5300DVD
JL Audio 10W7AE
JL Audio H.O Box
Audison LRX300.4
NSB90 Battery
broadblaster
PostPosted: Sun Mar 11, 2012 4:31 pm Up
temps will allways rise when car is stopped as the pump is not runing. to the op i would be looking at the thermostat.
on a back road playing
138Andy
PostPosted: Sun Mar 11, 2012 4:37 pm Up
mines exactly the same dude when i stop in traffic it just goes up and up until the car starts screaming STOP!
went to the garage he said its the relays on the fan just hook it up to a switch on the dash and flick it on and off when your stopped doing mine in 3 weeks when i get some time off let me know how you fix this might help me do mine Razz
kit325
thermostat perhaps? cheap and easy option to try out under a tenner.
Did u do the head gasket urself? doing it properly? Skemmed the head?
kit
millerman
PostPosted: Mon Mar 12, 2012 3:38 am Up
I had the same symptoms on my Wifes car, but that is the 1.4 8v, i changed the rad 'cause it was knackered, i changd the temp sensor 'cause i thought the gauge on the dash was reading incorrect, i changed the stat, i bled the system and the gauge still went up to nearly red!! Evil or Very Mad
But, i've now got it to sit at 90deg when up to temp, the reason? A BLOODY MASSIVE AIR LOCK!! Dont ask me why i decided to bleed it a second time, i just did and real glad i was too. The rad was bled and only a tiny amount of air escaped, nipple above the stat was bled, same as rad, small amount of air, the real culprit was the bleed nipple on the heater hose going into the bulkhead, a luke warm heater told me all was not right, i undid the nipple completely and coolant poured out, the coolant suddenly stopped and the coolant in the resevour dropped like a stone, i quickly added coolant to the resevour and with this a mass of coolant was forced out of the bleed hole, yup, one helluva air lock!! Took car for a spirited drive, left to idle then switched off. 2hrs later coolant level is fine, heater is HOT and temp gauge reads 90deg when hot, job done. Hope this helps fella.
If you think no one cares, try missing a mortgage payment!
Gra1n
PostPosted: Mon Mar 12, 2012 7:07 am Up
I'v thanged the two sensors on the engine block it self which apparently are the temp sensors.
The head has been done professionally, head skimmed, new head bolts, original gasket, the works!
I'm gonna try the air lock thingy! but i really dont think that could be it on mines but ultimately its worth a try.
Keep the replies coming because i need all the help i can get! haha
Someone told me there was a recall on the Peugeot 206 Roland Garros 1.6 AC model about the fan not kicking in but i can't find it on the internet at all.
Also my fan sometimes kicks in at 110degrees, is this normal or does that mean its over heating? Bearing in mind boiling point for water is 100degrees
Thanks a lot for your feeback!!
Pioneer AVH-5300DVD
JL Audio 10W7AE
JL Audio H.O Box
Audison LRX300.4
NSB90 Battery
PostPosted: Mon Mar 12, 2012 7:16 am Up
If there was a recall & the car had missed it then you would have had a letter from Peugeot by now.
You can always ring Peugeot customer service or a main dealer / pop in & ask if there is any recalls outstanding.
PostPosted: Mon Mar 12, 2012 7:42 am Up
Why not just fix the relays? Much easier.
PostPosted: Mon Mar 12, 2012 7:46 am Up
Not when it's under pressure....
PostPosted: Wed Mar 14, 2012 2:52 pm Up
The max system pressure (controlled by your radiator cap) is 1.4 bar. At that pressure water boils at 120 deg C. despite that 110 degrees sounds a bit high - most cars I have dealt with the cooling fan kicks in at around 100 deg.
However I do not know what the operating temperature is for your fan to kick in - perhaps a more knowledgeable member will be along in a minute. Also bare in mind that your gauge may not be accurate and often aren't.
