Posted: Sun Jan 09, 2011 2:52 pm |
gearbox went on me so i got box off ebay that said it was the right 1 and looked same as well but when old 1 was dropped out and new 1 put back in it went in fine drivers side driveshaft went in fine but passinger side driveshaft seems 2 be 2 big is the box from the 1.1 or a diffrent year or sumert like that and can i just put a smaller driveshaft in or is it a new gearbox agen
thanks
Posted: Sun Jan 09, 2011 3:03 pm |
bigger driveshaft, First time I heard this lol
No all the TU engines use the same box just different ratios
Have you pushed it all the way in?
Posted: Sun Jan 09, 2011 5:28 pm |
Too big or too long?
| NO LONGER ACTIVE ON THE FORUM | |
Posted: Sun Jan 09, 2011 11:55 pm |
Too long
Posted: Mon Jan 10, 2011 4:18 am |
by how much roughly? Are they motor factor shafts or pug oem ones?
Posted: Tue Oct 04, 2011 6:07 am |
Was this ever sorted? Same problem here :/
Posted: Tue Oct 04, 2011 11:08 am |
mattievrs wrote: |
Too big or too long? |
You referring to his first sentence?
Posted: Tue Oct 04, 2011 1:21 pm |
Edward wrote: |
mattievrs wrote: |
You referring to his first sentence? |
