Latest: Worthy967
Overall: 17143
Online Now [591]:
Visitors: 590
Today: 159003
Total: 115643920
Forums › The Car › 206 Talk › Cheap way of lowering
matty_riddell
PostPosted: Thu Sep 29, 2011 9:39 pm Up
Looking for an extremely cheap way of lowering my car,
Any ideas?
hi
PostPosted: Thu Sep 29, 2011 11:32 pm Up
Let the tyres down, or get 4 fat friends to always sit in the car.
-Dave-
PostPosted: Fri Sep 30, 2011 12:00 am Up
Trade Rating: +36
Springs. But then you would more than likely have to change at least the droplinks and the top mount bearings while you were there and then factor in the cost of getting the torsion bar done if you can't do so yourself. In not so many words there isn't really a cheap way without cutting corners which could cost you more in the long run. Save up and do the job properly first time would be my suggestion.
Ex 206 Owner.
PostPosted: Fri Sep 30, 2011 12:39 am Up
If you can do it all yourself £30/£40 for some spring and that's it.
Tho cutting the springs will make it free Laughing (I joke, never cut you springs Razz )
spud_owen
PostPosted: Fri Sep 30, 2011 1:53 am Up
buy my struts with lowering springs already on, stright swap over, will probably just need drop links, see my forsale theard
Honda Accord cdti....205GTI
LACEY AND OWEN ARCHITECTURAL SERVICES
www.laceyandowen.co.uk
woodthorpe1717
PostPosted: Fri Sep 30, 2011 2:39 am Up
i would always recomend spending an extra couple of quid and get coilovers, for what you can pay for springs you might aswel wait an extra couple of weeks and get a little bit more money and get coilovers. more secure, better ride and more reliable. then do your torsion bar yourself (its easy, even guides on youtube or written guide on google)
1.9 Diesel NON turbo.\r\nWho needs power?!
PostPosted: Fri Sep 30, 2011 3:01 am Up
Remove the rear axle and all wheels for that 'slammed' look.
Andy180
PostPosted: Fri Sep 30, 2011 3:17 am Up
None of that is true.
GTI 180
Mattie-RS
PostPosted: Fri Sep 30, 2011 3:51 am Up
Like Chris said, just take the whole suspension out.
It's only a luxury!
PostPosted: Fri Sep 30, 2011 3:59 am Up
Agreed, sounds like someone has been feeding you bulls**t, if anything it's the exact opposite of what you just said.
As for cheap lowering you can get used springs for £20-£30 and then just the labour or do it yourself. Can't get much cheaper really.
Seb
PostPosted: Fri Sep 30, 2011 4:01 am Up
Staff - Seb
Not true at all.
craigy00craig
PostPosted: Fri Sep 30, 2011 5:11 am Up
Here you go. The cheapest and best way to lower and car imo
www.206info.co.uk/Foru...c/t=34863/
Progress Threads:
