Posted: Mon Oct 03, 2011 12:30 pm |
Hi Guy's,
Been lurking on here for a while and need some help.
I have a 2002 (51) 206 1.4 Auto and recently the temp gauge sometimes fly's to the red, the stop light flashes for a while and then comes back down.
I believe that it might be the coolant sensor but have no idea where it is located.
Any help would be welcomed.
thanks
Posted: Mon Oct 03, 2011 12:34 pm |
at a guess i would say it would be on the thermostat housing
Posted: Mon Oct 03, 2011 12:39 pm |
should be on the passenger side of the engine bay, a green plug with wires going into it
Posted: Mon Oct 03, 2011 12:41 pm |
Thanks.
Shall have a look tomorrow.
Does what i described sound like it could be that?
Posted: Mon Oct 03, 2011 12:44 pm |
Do you have a multimeter?
Posted: Mon Oct 03, 2011 12:45 pm |
Could be, had the same problem and went away when i changed the sensor
Posted: Mon Oct 03, 2011 12:50 pm |
Fingers crossed that it is that.
No multimeter im afraid.
Posted: Mon Oct 03, 2011 1:24 pm |
oo oo oo oo i recently had this problem, i replaced the coolant sensor and it still did it, in the end what it was was that the wires & relay to the fan had corroded and the fan wasn't kicking in, i replaced them and made it work and it's not done it since. the coolant sensor was the most expensive bit :/
